plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 4th, 2018, 09:04 AM   #1
mohamed abd el raouf
Egypt
mohamed abd el raouf is offline
PCS 7 , FB66 , Motor
Hi all ,
Where i can find the description of each function for i/o in fb66 motor control in PCS7 V8.2( it's locked in my case and F1 not working )
the following picture is taken from Siemens web site
Old March 4th, 2018, 12:26 PM   #2
cardosocea
United Kingdom
cardosocea is offline
Have you tried reading this:
https://cache.industry.siemens.com/d...l80b_en-US.pdf
PCS7's IO are all standardised and will do the same thing independent of block. So it is worth reading the standard first and then dive into the block functionality otherwise, some bits may be confusing.
Old March 5th, 2018, 01:11 AM   #3
Egypt
Thanks for the help
meanwhile i'm reading this 1898 page , from where i can download the block functionality ?
Old March 5th, 2018, 10:34 AM   #4
cardosocea
United Kingdom
Ok, I had a better look now and the MOTOR block is actually from the APL7.1. The document I linked is for APL8.2 as I assumed that would be the library you would be using.
The link that explains that block is here
https://www.google.co.uk/url?sa=t&rc...W4xKJpB81_jawc
But the same I said earlier applies... unlike a PLC programming language, you should read up the standard used in the symbology before writing code as it will be harder this way.
Why version 7.1 of APL?
Old March 5th, 2018, 11:18 AM   #5
Egypt
Thanks for the reply
this document is close enough to what i was looking for ( fast look )
i am trying to explore PCS7 on my own throw program given by friend before i decide if i take Siemens course or not ( it will cost me about 13000 local currency and this is a huge huge amount and i have only 1 week before course start )
i think the reason for 7.1 is that the machine was manufactured on 2008 and no updates have taken place since this time
Old March 5th, 2018, 11:28 AM   #6
cardosocea
United Kingdom
That document should be what you are looking for... if the machine was made in 2008, it is not running PCS7 8.2... if you had said that I would have pointed you to the right place straight away.
Do you know PLC's? Are you planning on working in a place that has PCS7? Are there places with PCS7 where you are now?
Old March 5th, 2018, 11:37 AM   #7
Egypt
sorry for not saying that , as my friend told me that the already install V8.2
i have a good knowledge for PLC ( you can say intermediate level) , yes i am planning to work in a place that have PCS7 , at least i have been asked if i deal with DCS system in most of my recently interviews so i am taking the next step , i am in Egypt
Old March 5th, 2018, 11:43 AM   #8
cardosocea
United Kingdom
If you know PLC's and the investment (paying for the course) will bear fruits (a new job or higher salary) it's definitely worth it.
It's not impossible to learn PCS7 by yourself, and there are plenty of information around to get you there, but I found it particularly hard on some peculiarities around the HMI setup and connection with other systems (particularly their historian).
I would definitely go for it... at a certain point in my career I was definitely planning on doing the same myself.
Do read up about the CFC charts as they are great, but require some knowledge on how to run logic. Usually you'd put your code in OB1 and that is it.
With PCS7, none or very little code, goes into OB1 and everything goes into the timed OB's. This creates some problems with the logic if you are not aware of it.
Good luck with the course and your job prospects too.
Old March 5th, 2018, 11:46 AM   #9
KalleOlsen
Norway
KalleOlsen is offline
Hi Mohamed!
You might find something useful here:
http://w3.siemens.com/mcms/sce/en/ad...s/default.aspx
Kalle
Old March 5th, 2018, 11:50 AM   #10
Egypt
i can see a lot of help here
i appreciate this form both of you
Old March 5th, 2018, 02:47 PM   #11
cardosocea
United Kingdom
I think Kalle helped me out before with the same link.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Magnetic motor contractor with motor overload - help backendcode LIVE PLC Questions And Answers 28 September 14th, 2017 10:59 AM
Motor FLA is NOT to be Used to Size Motor Conductors ! Lancie1 LIVE PLC Questions And Answers 10 April 13th, 2013 07:13 AM
Blew a motor... Greg Dake LIVE PLC Questions And Answers 14 October 9th, 2008 08:40 PM
Automation or not ? Pierre LIVE PLC Questions And Answers 23 May 26th, 2004 06:06 AM
Motor guru's I need your help... Russ LIVE PLC Questions And Answers 50 July 17th, 2002 05:11 PM
