Wonderware DAServer holding onto RSLogix5000
echos
Nov 2010
Edmonton
49
I am trying to break the link between a wonderware tag and a tag in RSLogix. No matter what i do to the tag in the PLC the wonderware is holding onto it.
I know i need to reset a cache somewhere but can not remember where to do it.
Has someone come across this before?
TIA
Got it, had to uncheck auto load tags in the SMC
What did you mean by "wonderware is holding onto it"?
I've had tags in a CLX PLC that I couldn't delete because they were being read by a DA server, but I don't understand what was happening in your case. Were you unable to delete the tag from the WW database?
Yes i could not delete the CLX Tag as it was being read by the DAServer, so i undeployed the wonderware tag then i renamed CLX Tag to TagOld and pointed Wonderware to read TagNew but no matter what i did wonderware would always point to TagOld even though the input source was told to look at TagNew
Having a Issue at a site where WOnderware can seemingly connect to the PLC and all shows good except its locked into a loop for downloading the...
1,833
Hi, I have a Legacy project that I have converted from Intouch 7.1 to intouch 11.1 now running on windows 10. I have also uprevved the DA Server...
3,593
Hi all wonderware users As I'm new to this and cant find a solution for the error message STS=1E I'm using a Intouch v10.5 connectet to...
3,559
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,437
Hello all, I am developing HMI screens for a Wastewater Treatment Plant which is using Modicon M580 PLCs that are running Unity Pro XL version...
3,873
