SLC 5/04, communication instruction
ade
Mar 2005
Bandung, West Java, Indonesia
46
Hello everyone.
Using MSG (Message Read/Write) instruction, can we use this intruction via DH+ communication network within SLC 5/04 processors. I have read the help menu in the RSLogix 500, it doesn't explain this instruction in DH+ network. I want to access some addresses at, let say, SLC#1 and use them in the SLC#2.
Your comments, suggestion and explanation will be greatly appreciated.
Best regards,
ade
No the help file doesnt explain well about messaging with DH+.
But the "trick" is that DH+ is Channel 1 in the setup screen for the message instruction.
Thanks Jesper,
Back to the target, how can I access the adresses of the SLC 5/04 processors to be manipulated in the other SLC 5/04 processor which connected via DH+ network. I mean what kind of instruction to be used. The help menu explain it in the DH485 network.
As Jesper mentioned Channel 1 will give you access to communicate through DH+. Take note the "Control Block" is a set of 14 data words starting the address you assign with. And the data you want to convey is set in the setup screen - "Data table address"
I just noticed your last post after I posted, you do not have to program anything special, the contents in the "Data table address" + the "Size in elements" (words) will be read or write as you assigned in the MSG instruction.
I'll start off by saying I'm unfamiliar with communications between PLC's, hence my question here. We have a machine with a ControlLogix & a SLC...
2,798
Hi, I have a problem with a cpu slc 5/05 (1747-L552), 32k Mem 0S501 series C, I am using the MSG instruction to ethernet communication, it works...
9,319
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
253
Hello, I need to connect with a SLC 5/01 (1747-L511) in order to see what is the current program that it has, since I don't have a lot of...
730
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
445
