Beginner-Siemens S7 counter-Ladder
tee
Apr 2005
I am a complete beginner with PLCs - so please forgive my ignorance.
System: Siemens S7-313C
Programming: Step 7 Ladder Diagram
1. How to you know the available counters?
2. How to you know which reference/label to use?
If possible, could someone provide a walk through for an "Up Counter" that counts to 10?
Thanks,
Tee
Thanks for he answers!
Hopefully might start making some progress now.
Cheers,
Tee
The help file within Simatic Manager is excellent so you can click on any programming element (ie. up counter) and press F1.
You'll see a description of the element, what inputs etc it needs, and also some examples of its use to get you going.
This obviously applies to all the other programming elements too..
Hi I have just started using Siemens S7 PLC for a mechatronics degree. I have used Matushita PLCs before but I am having difficulty with Siemens...
3,676
Hello All, I am looking for an absolute beginners guide to programming in STL. I am just starting out with SIEMENS PLC's. CPU's that I will be...
4,642
Hey fellas, We just bought a used machine that's run by an S7-300. Our facility, however. is all AB, so our plan is to convert. I have a copy...
4,370
hello i am learning PLC techniques.but i need to use the free simulator on this site but unable to find a way out on how to run it. i need to...
1,915
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
274
