plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 19th, 2005, 07:00 AM   #1
Chandrashekar
Saudi Arabia
Chandrashekar is offline
Pc/rs 232 Siemens Converter 6es5 734-1bd20
Dear sir
Iam here with compaq 1200 laptop with installed siemens S5 plc programming software and siemens PC/RS 232 CONVERTER 6ES5 734-1BD20
Iam asking you How to connect this cable to laptop
This cable has 1 side 15 pins male connector another side 25 pins female connector.I connectted 15 pins side to plc, but another side 25 pins connector how to connect my laptop.my laptop having 9 pins port only
Old November 19th, 2005, 07:50 AM   #2
lhughes39
United States
lhughes39 is offline
Port Adapter
You need a port adapter. It will adapt your 9 pin serial port to a 25 pin to fit the Siemens cable. I know you are not in the states, but Radio shack here in the states carries them. You may be able to find one at your local electronics dealer.
__________________
Anyone who has never made a mistake has never tried anything new - Albert Einstein
Old November 19th, 2005, 09:35 AM   #3
Chandrashekar
Saudi Arabia
Port adaptor
I have 1 adaptor with me,it has 1 side 25 pins male connector another side 9 pins female connector.I can use this
pls, suggest me
Old November 19th, 2005, 09:46 AM   #4
krk
England
krk is offline
Well...the 6ES5 734-1BD20 uses only 3 of the pins on the 25D connector so if your adaptor has wired as a minimum...
D25 ________ D9
2 ------------ 3
3 ------------ 2
7 ------------ 5
....then it should work
__________________
www.krkautomation.com
Old November 19th, 2005, 10:16 AM   #5
Chandrashekar
Saudi Arabia
Connection details
9 pins female connector-25 pins male connector connection details
9 pins maled connector--------25 pins female d connector
1---------------8
2---------------3
3---------------2
4---------------20
5---------------7
6---------------6
7---------------4
8---------------5
9---------------22
that means i can use this connector
thanks
Old November 19th, 2005, 10:30 AM   #6
nswu1
United States
nswu1 is offline
nswu1's Avatar
Wink
In the following circumstances I always make my cables, using off the shelf cables with wires not needed sometimes makes problems. Just make a 3 conductor cable using the 3 pins stated above with a db25sub on one side and a db9sub on the other.
Old November 19th, 2005, 12:17 PM   #7
lhughes39
United States
Port Adapter
Chandrashekar;
That sounds like the adaptor that I use (i just looked at mine to make sure). Just plug it in to the Siemens cable and then into the RS 232/serial port on your laptop and it should work if the software is configured correctly.
__________________
Old November 21st, 2005, 03:26 AM   #8
Chandrashekar
Saudi Arabia
25 Pins - 9 Pins adaptor
Thanks Mr.lhughes39 and krk
Siemens Cable is working with my laptop
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rs 232 / Tcpip Converter mahdi_rtt LIVE PLC Questions And Answers 5 November 24th, 2004 07:55 PM
USB to RS232 converter with Siemens luca.bettinelli LIVE PLC Questions And Answers 1 March 6th, 2003 08:36 AM
