Edict 97 software?
alanmarshall
Mar 2006
Ohio
I have cegelek 80-400 PLCs with ALSOP communicators. A communicator went bad and when it was replaced we found that the software has disappeared. A new copy was obtained from Red Lion, but it isn't backward compatible! Red Lion says they don't know where an old version could be located, just update to the new software. Not an option due to the time involved. Where might I find a '97 version of Edict 97 software?
I am not sure who you spoke with, but Edict 97 should work with all units. Are you sure that the HMI you have needs Edict 97 and not Edict 1.5? I can provide older versions of Edict 97 or Edict 1.5. What does the unit say when you power up, it should say Edict XX Runtime and below it a firmware version. Send me an email, [email protected], and let me know what version your HMI is running. I can provide a version of Edict that will work for you.
Regards,
Doing an HMI conversion of an old Paradigm unit. Customer sent a****.edb file (attached). He told me I needed EDICT-97 on a windows XP machine but...
1,165
I have an old Red Lion HMI (model VX500) programmed with Edict-97 and I want to pull the program off of it and put in on a newer Red Lion HMI. Is...
4,248
32
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
114
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
105
