This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Oct 2006
Simulating a S7 200 prog. on 300 simulator
Hello,
I have an old S7 200 with a 214 CPU. The program it is running is written in LAD form. Only Digital I/O is used, and now expansion modules are attached. I want to simulate this program, and thought of using Siemens' PLCSIM or WINPLC. All I am looking for, is to find any problems in the program if an unexpected Input is encountered: So I want to monitor I/O and memory locations when simulating different Inputs. I do not care about the scan time (it is a slow process anyway). I do not think I need a 214 compatible Emulator to do the simulation work, or what? I mean, the CPU 214 program is written in Ladder form and I guess I can recreate the same Ladder logic on a S7 300. Comments are highly appreciated ! Geir Ove |
#2 |
![]() Join Date: Aug 2003
I made a small search and found this in another forum.
It's a simulator for the S7-200 and also S7-200 TD. There are other interesting things in the page. The page is in spanish http://personales.ya.com/canalPLC/ for the download section go to: http://personales.ya.com/canalPLC/descarga.htm there is also an english version of the software. I didn't try it, but it seems a nice simulator.
__________________
I am responsible for everything... except my very responsibility. J.P.Sartre |
#3 |
Hello,
Thanks for the answer. I have seen this stuff. However, as with WINPLC7, there is very little documentation and few users and nobody answers any mail.... In this case, I have a client waiting for results, and they pay for the software, so I can buy, within reason, for what we need. The question remains: Can I successfully use a 300 simulator for my 200 simulation needs: Se origina posting for details. Geir Ove |
#4 |
Can you buy a S7-200 and use it for your simulation ? Replace the i/o with flags (if an S7-200 has them - I'm not familiar with the 200 range).
#5 |
Hello,
Thanks for the input. Yes I can use a 200 PLC to debug the application. However, as I will be doing a lot of travelling on this project, I would prefer the convenience of having a Simulator / Emulator on my PC that goes with me wherever I am... :-) Geir Ove |
#6 | |
Quote:
The downloaded version asks for a 'acces key'. I can not read spanish but my guess is that you have to buy 'it'. As it is, I can not test this software. |
#7 |
Hello,
Yes I have seen it. No support. Answers in italian. What more can I say? Still my original question remains unanswered Geir Ove |
#8 |
I never have worked with S7-200, but from the few minutes I have looked at it, I remember that counters and timers have a different build up. This difference you should be able to check out with your software and WINPLC. WINPLC is not so difficult.
Maximum 20 segments per block, but you can always call a different block in one of those segments. I really do not know how many blocks you can use. Then 'send all blocks', switch the cpu in RUN-mode (switch on the right side) and 'view process image' to emulate I/O's. It is even possible to monitor counters and timers like this or change I/O-adresses |
#9 |
In the same forum, they say to try with 6596 for authorization. The man in the web page does not answer mails. I have not try it so I didn't know the number was so important
I write to the people there, If they tell me it has some cost, I'll let you know. (If they answer). There is no strightforward way of making the simulation of the S7-200 with the S7-300 simulator. The code is not 100% equal. So for that, you should write your code twice. One for each processor, and be very carefull with the behavior of the instructions. Specially timers and counters and other blocks like that. For that mater, if you write your code for any other PLC simulator, you will have the same results. S7-200 and S7-300 are quite different.
__________________
I am responsible for everything... except my very responsibility. J.P.Sartre Last edited by sapoleon; October 24th, 2006 at 02:15 AM. |
#10 |
Hello JP,
Thanks for the answer. Yes I understand that the instructions are different, and that I probably have to write the program twice: Luckily it is not a large program, and we are going to phase the 200 out. The program only uses two delay timers and one MOVE Byte instruction: The rest is reading / writing I/O and Memory locations. I think I can recreate this logic in a S300 simulator! Geir Ove |
#11 |
I get permission from J.L.Villanueva M. to distribute the access codes of the programs in the forum.
Clave del programa S7_200: 6596 Clave del programa PC_SIMU: 9966 Clave del programa CADe_SIMU: 4962 those are de codes, I think that only the S7_200 is in english, I'm not sure thou. there are the codes for you, and thanks to J.L.Villanueva M
__________________
#12 |
![]() Join Date: May 2005
we did something like what you wanted to do .
I think it is possible if you know the differnces between s7-200 and 300 . it deends on the complixity of the program may be you can send the the s7200 program and we would be able to judge how succesful would it be |
#13 |
what is winplc ?
by the way take care the etension modules for 214 is different from those you can buy now from siemens , the s214 where puggable into each other (without the samll flat cable) |
#14 |
Yesterday I have tried the S7-200 simulator. It worked with code like:
A I 0.0 = Q 0.0 but when I used a timer, it didn't do what is was supposed to do. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Any display with Siemens S7 200?? | Preeya | LIVE PLC Questions And Answers | 6 | January 14th, 2007 05:10 AM |
| Shift register S7 300 | alielectrical | LIVE PLC Questions And Answers | 16 | December 5th, 2005 08:42 AM |
| Free S7 300 Simulator | kartik | LIVE PLC Questions And Answers | 3 | December 3rd, 2005 12:51 PM |
| Simulator, Simulation, Shadow Code | Terry Woods | LIVE PLC Questions And Answers | 1 | January 2nd, 2005 01:40 PM |
| s7 200 master - slave | Farid | LIVE PLC Questions And Answers | 1 | March 14th, 2004 11:09 PM |
