Unity pro - simulating analog inputs
akash11132
Jun 2017
Sydney
45
Hi Everyone,
As part of FAT testing, I am looking to test the PLC logic by simulating the analog inputs. Is there any way to feed analog input values for Level, Pressure and flow automatically based on the feed pump speed, discharge pump speed and valve positions. I am not using Animation table to enter analog values.
Regards,
Akash
Hi Everyone,
Regards,
Akash
This Youtube video shows you exactly how to do what you want.
https://www.youtube.com/watch?v=QwyRlXl8KQQ
@Chris Taylor Thanks for that. Got an idea to feed simulated value into the PV. The problem is to simulate( increase and decrease) the level of a tank based on the valve position, feed rate and Discharge.
Is there any way to create a variable that automatically increments based on the incoming feed rate and automatically decrements based on the outgoing discharge rate. Thanks in advance.
1)Is there a way to simulate Analog input instead of a instrument in the simulator mode to test the software? like plcsim in Siemens you are...
2,105
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
717
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,929
