Unity Pro, Issue with multiple line IO Scanning for single device.. only Two working ?
Para
Feb 2024
Manchester
Hello,
I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE.
I have attached screenshot for reference.
First 3 devices on IO scanning works fine. I have configured 2 devices (one from line 4 to 10 and second device from line 11 to 19). Both these device models are same.
I have configured first device with multiple IO scanning lines to read total 640 Modbus addresses. Separate lines are created to read data in length of 100 each and last one to read 40. I have set the Unit id to 1 for this device. However, I can get comms with only two IO scanning lines (line 4 and 10). Rest of the IO scanning lines are not communicating.
I have tried changing the unit id of both devices to 255 and got similar result, the comms was established for IO Scanning Line 4. However, instead of line 9, the comms was established for line 10.
I can ping these devices from the network and also can see it is working from its web page. I am also able to Modscan the device.
Could anyone please suggest what can be the issue?
Is this possible? Each line in the IO scanner table opens a separate connection to the Modbus/TCP server you are trying to read from. The server supports a limited number of concurrent connections and you are out of them. Try launching multiple Modscan instances and see how many will poll one of the Modbus/TCP servers.
Thank you KirkC. I have tried mod scanning the device multiple times but for some reason it’s not working and after few attempts its crashing. I am getting Error "TCP/IP connection terminated!”. However, In the past, after few attempts, I had been able to Modscan the device. Also, I am still able to ping the device IP.
The IO scanning has worked before for old device with same configuration (only unit ID was different). However the device has been replaced recently with new one. I changed the Unit Id to 1 to match new device in IO scanning and kept rest of the configuration as it is.
Hello KirkC. I checked the device manual and it says " The driver is also capable of being accessed by two TCP/IP client devices simultaneously." I think this means I can have only two connection to this device. Do you have any idea what can be the best way to configure IO scanning for this device to read 640 modbus addresses. Thank you.
I am using Unity Pro 13 XL- running on windows 7 OS. The program is in Simulation mode. When I try to connect it to the Simulator , I am getting...
5,570
Hi All, Unity Pro XL V7.0 with a DP/DP Coupler, Release 2 - Siemens AG, I'm making some modifications to a brownfields site. I have added the...
2,962
I have an ebool variable that I want to access via modbus as read only. This variable is set in the PLC logic when a tanks level is high. When I...
7,692
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
716
