plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 30th, 2008, 08:59 AM   #1
Shawn Cassidy
Canada
Shawn Cassidy is offline
Shawn Cassidy's Avatar
Microscan MS-3 Laser Matchcode issue
I was wondering if anyone has experiance with the Microscan MS-3 laser matchcode set-up. I'm reading a label with 2 barcodes on it. I've set-up the scanner to learn both barcodes and place them in the master database. When a good label passes in front tof the scanner I have a good read output. When I pass 2 bad barcodes I don't get the good read output (what I want). The problem is sometimes the labeller will apply 2 labels on a bottle and they will overlap. If overlapped, there will only be one of the 2 barcodes visible. The scanner will read the two (same) barcodes and give me a good read even though it only read the first barcode twice. Also, if I make up a label with one good barcode (matching the master database) it will give me a good read and disregard the bad one. I'm certain I'm missing something in the set-up procedure.
Old May 30th, 2008, 10:47 AM   #2
Shawn Cassidy
Canada
Talked with Microscan and it can't be done. Apparantly they look at both symbols and if either match it outs a good read/match pulse. They don't have a funtion to say both match codes need to match then output... too bad.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
