This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Dec 2005
choosing capacitor when translate 3 phase AC motor into single phase
Hello colleagues,
How it is go on, I have one question, maybe simple for some experts, I need to know, how calculate which capacitor we are need when transformed 3 phase AC motor in single phase motor, I know one formula C= 70 √P, when is C in metric units micro F(Farads) and P is power from AC motor in W(Watt), in example: P=100w when computing we are to receive very strange results approximately 700 micro F, of course I’m informed about chart for choose volume capacitors. Thank you for replay Aleksandar |
#2 |
![]() Join Date: May 2008
Hi Aleksander ,
Your question is not clear Please explain what you are trying to do You can run a single phase motor from a 3 phase supply if you have a suitable/safe means of connecting it to a local distribution board Not sure why you are requiring to connect capacitors unless you need to provide power factor correction more information please |
#3 |
I believe he's trying to do the opposite - run a 3 phase motor from a single phase supply using capacitors in some way.
__________________
Controlling outputs is the PLC's way of getting its inputs to change. www.thePLCguy.com |
#4 | |
Quote:
We need alot more detail if you would like us to assist you. |
#5 | |
![]() Join Date: Nov 2004
Quote:
Are you trying to run a single phase motor off 3 phase and need to know the capacitor value for the motor? ANSWER Look on the nameplate or call the factory. Are you trying to run a 3 phase motor on single phase? ANSWER There have been several methods to do this - you can still do any of them. BUT if motor is 3 HP or less you can get VFD to run off 120 single phase 50 HP or less you can get VFD to run off 230 single phase WITH much less hassle and LESS or maybe equal cost. Dan Bentler |
#6 |
You will not achieve satisfactory results trying to run a three phase motor on only single phase with a capacitor. However, if you add a second motor as an idler motor with a small capacitor to get the second motor started, then you can achieve some marginal results. The idler motor will generate your third phase, however you won't have the motor full rated power. This set up is called a rotary phase converter, and if you search google.com for rotary phase converter you can find many websites with detailed instructions on how to set one upand how to size the ilder motor and the capacitor. For general purpose three phase motors and three phase motors on simple machine tools this is an economical and frequently used alternative.
More expensive options are VFDs and motor/generator sets.
__________________
True craftsmanship is only one more power tool away. That's the beauty of processors, they don't have emotions they just run code - The PLC Kid. |
#7 |
A couple of links I found regarding this
http://www.home.earthlink.net/~ojmsmith/ http://www.freepatentsonline.com/4792740.html
__________________
#8 |
You can run a small (personally had good results up to 0.75kW) 3-phase motor on a single phase net by simply adding a running capacitor.
C = 70 x kW (formula for 230/400V 50Hz 3-phase motors to run on a 230V 50Hz single phase supply) For example a 0.37kW motor would require a 25µF cap. You'll have to keep in mind that starting torque drops dramatically, but for pumps or other low starting torque applications it is a simple and effective solution (so forget about running an 3-phase air compressor). Hope this helps |
#9 | |
Quote:
#10 |
Vsd
Why not use a single phase to three phase frequency drive, should simply need to connect the motor in Delta instead of star. I have several of htese onsite and they are valiable from a variety of suppliers I use SEW and AB.
Cheers Peter |
#11 | |
Quote:
Real crappy in my opinion....
__________________
Regards Dave "When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity." Albert Einstein (1879-1955) |
#12 |
Hi Lancie,
Dave beat me to it in answering your question... but also Peter has a good point. Nowadays the cap solution is only used for economical reasons: A perm cap costs around €5 to €10, while a VFD costs about twenty times as much. On the other hand, you wouldn't have to worry about torque when using a VFD, so you could run any application (up to 3kW I think?) on a single phase. BTW, the Steinmetz connection has been around for decades, way before there were "fancy" VFD's ;-) To Dave: We also do motor rewinds (dad started back in the late 60's). |
#13 |
Thanks a lot for respond every body, some people think this is wonder because today we are have many ways for solve this problem like as vfd, problem is money ,one permanent capacitors is much chipper then vfd,I know all about loosing power and moment inertia when three phase motor work like single phase, when motor give us enough power it is better solution, money we are spend on others things. And again thanks for replay, Aleksandar |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Single Phase Inverter question | eddycheong | LIVE PLC Questions And Answers | 30 | April 2nd, 2008 02:30 AM |
| Start of single phase AC motor - theory and practice | Pandiani | LIVE PLC Questions And Answers | 5 | January 29th, 2007 09:49 AM |
| motor 3phase to single phase | billyboot | LIVE PLC Questions And Answers | 22 | July 6th, 2005 07:14 AM |
| single phase ac motor | ushakkal | LIVE PLC Questions And Answers | 1 | January 12th, 2003 02:24 AM |
| Mechanical/Material Handling and ISA 88 | rlmunoz | LIVE PLC Questions And Answers | 6 | December 25th, 2002 02:49 AM |
