DATA_BLOCK DB 88
TITLE =
VERSION : 0.0
FB 1
BEGIN
wDataToAdd := W#16#0;
bAddToFIFO := FALSE;
bRemoveFromFIFO := FALSE;
wDataFromFIFO := W#16#0;
wFIFO[1] := W#16#28;
wFIFO[2] := W#16#0;
wFIFO[3] := W#16#0;
wFIFO[4] := W#16#0;
wFIFO[5] := W#16#0;
wFIFO[6] := W#16#0;
wFIFO[7] := W#16#0;
wFIFO[8] := W#16#0;
wFIFO[9] := W#16#0;
wFIFO[10] := W#16#0;
wFIFO[11] := W#16#0;
wFIFO[12] := W#16#0;
wFIFO[13] := W#16#0;
wFIFO[14] := W#16#0;
wFIFO[15] := W#16#0;
wFIFO[16] := W#16#0;
wFIFO[17] := W#16#0;
wFIFO[18] := W#16#0;
wFIFO[19] := W#16#0;
wFIFO[20] := W#16#0;
wFIFO[21] := W#16#0;
wFIFO[22] := W#16#0;
wFIFO[23] := W#16#0;
wFIFO[24] := W#16#0;
wFIFO[25] := W#16#0;
wFIFO[26] := W#16#0;
wFIFO[27] := W#16#0;
wFIFO[28] := W#16#0;
wFIFO[29] := W#16#0;
wFIFO[30] := W#16#0;
wFIFO[31] := W#16#0;
wFIFO[32] := W#16#0;
wFIFO[33] := W#16#0;
wFIFO[34] := W#16#0;
wFIFO[35] := W#16#0;
wFIFO[36] := W#16#0;
wFIFO[37] := W#16#0;
wFIFO[38] := W#16#0;
wFIFO[39] := W#16#0;
wFIFO[40] := W#16#0;
wFIFO[41] := W#16#0;
wFIFO[42] := W#16#0;
END_DATA_BLOCK
FUNCTION_BLOCK FB 1
TITLE =
VERSION : 0.1
VAR_INPUT
wDataToAdd : WORD ;
bAddToFIFO : BOOL ;
bRemoveFromFIFO : BOOL ;
END_VAR
VAR_OUTPUT
wDataFromFIFO : WORD ;
END_VAR
VAR
wFIFO : ARRAY [1 .. 42 ] OF WORD := W#16#28, W#16#0;
END_VAR
VAR_TEMP
bCalcTime : BOOL ;
bElapsedTime : TIME ;
END_VAR
BEGIN
NETWORK
TITLE =add to fifo
A #bAddToFIFO;
JNB _001;
CALL "ATT" (
DATA := #wDataToAdd,
TABLE := #wFIFO);
_001: NOP 0;
NETWORK
TITLE =remove from fifo
A #bRemoveFromFIFO;
JNB _002;
CALL "FIFO" (
TABLE := #wFIFO,
RET_VAL := #wDataFromFIFO);
_002: NOP 0;
END_FUNCTION_BLOCK
ORGANIZATION_BLOCK OB 1
TITLE = "Main Program Sweep (Cycle)"
VERSION : 0.1
VAR_TEMP
OB1_EV_CLASS : BYTE ; //Bits 0-3 = 1 (Coming event), Bits 4-7 = 1 (Event class 1)
OB1_SCAN_1 : BYTE ; //1 (Cold restart scan 1 of OB 1), 3 (Scan 2-n of OB 1)
OB1_PRIORITY : BYTE ; //Priority of OB Execution
OB1_OB_NUMBR : BYTE ; //1 (Organization block 1, OB1)
OB1_RESERVED_1 : BYTE ; //Reserved for system
OB1_RESERVED_2 : BYTE ; //Reserved for system
OB1_PREV_CYCLE : INT ; //Cycle time of previous OB1 scan (milliseconds)
OB1_MIN_CYCLE : INT ; //Minimum cycle time of OB1 (milliseconds)
OB1_MAX_CYCLE : INT ; //Maximum cycle time of OB1 (milliseconds)
OB1_DATE_TIME : DATE_AND_TIME ; //Date and time OB1 started
bFalse : BOOL ;
bTrue : BOOL ;
END_VAR
BEGIN
NETWORK
TITLE =
O #bTrue;
ON #bTrue;
= L 21.0;
A L 21.0;
BLD 102;
= #bTrue;
A L 21.0;
NOT ;
= #bFalse;
NETWORK
TITLE =add
A #bTrue;
= L 21.0;
BLD 103;
A #bFalse;
= L 21.1;
BLD 103;
A I 0.0;
FP M 1.0;
JNB _001;
CALL FB 1 , DB 88 (
wDataToAdd := MW 100,
bAddToFIFO := L 21.0,
bRemoveFromFIFO := L 21.1);
_001: NOP 0;
NETWORK
TITLE =remove
A #bFalse;
= L 21.0;
BLD 103;
A #bTrue;
= L 21.1;
BLD 103;
A I 0.1;
FP M 1.1;
JNB _002;
CALL FB 1 , DB 88 (
bRemoveFromFIFO := L 21.1,
wDataFromFIFO := MW 102);
_002: NOP 0;
END_ORGANIZATION_BLOCK
