![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Jun 2008
All the light on s7-400 panel flashing
Hello guys,
I'm in trouble because all the light on s7-400 cpu panel is flashing ,i remove and insert to rock many times and download hardware configuration it can be okay at first but after a little time they will flash again,what the matter? enclose hardware diagnose list Event 64 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:42:43.416 PM 01/07/2009 Event 65 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:42:37.648 PM 01/07/2009 Event 66 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:42:12.142 PM 01/07/2009 Event 67 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:41:02.579 PM 01/07/2009 Event 68 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:40:52.240 PM 01/07/2009 Event 69 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:40:47.350 PM 01/07/2009 Event 70 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:40:15.241 PM 01/07/2009 Event 71 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:40:12.397 PM 01/07/2009 Event 72 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:39:47.414 PM 01/07/2009 Event 73 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:38:49.817 PM 01/07/2009 Event 74 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:38:26.963 PM 01/07/2009 Event 75 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:37:37.781 PM 01/07/2009 Event 76 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:36:53.401 PM 01/07/2009 Event 77 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:36:21.091 PM 01/07/2009 Event 78 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0000 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:36:16.365 PM 01/07/2009 Event 79 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:34:31.784 PM 01/07/2009 Event 80 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0000 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:50.866 PM 01/07/2009 Event 81 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0000 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:43.371 PM 01/07/2009 Event 82 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:39.054 PM 01/07/2009 Event 83 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:27.946 PM 01/07/2009 Event 84 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:26.510 PM 01/07/2009 Event 85 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:11.754 PM 01/07/2009 Event 86 of 120: Event ID 16# 3583 Accumulation of detected and corrected memory errors Not user-relevant (Z1): 0002 Requested OB: CPU hardware fault OB (OB84) Priority class: 25 Internal error, Incoming event 02:33:03.265 PM 01/07/2009 |
#2 |
Hello leon.LEE.
Either the CPU, the rack it sits in, or the PSU in the rack is defective, or there is excessive electrical noise in the plant.
__________________
Jesper ![]() 3 strikes and you're out
#3 |
![]() ![]() Join Date: May 2008
How you Jesper assume that? Do you think that there is so much electrical interference that it corrupts units ram? And how can it be from defective rack if so?
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
S7 400 H system and a redundant CPU | Sierk Goedemoed | LIVE PLC Questions And Answers | 1 | April 19th, 2010 10:02 AM |
Class Project | Plexico | LIVE PLC Questions And Answers | 33 | October 16th, 2007 07:03 PM |
s7 400 time stamps | udtwmc | LIVE PLC Questions And Answers | 0 | September 30th, 2005 08:41 AM |
S7 + MAC panel, communitating in multidrop instead of PPI | Exar | LIVE PLC Questions And Answers | 1 | July 3rd, 2005 12:33 AM |
Panel View+ 400 | tcf24m | LIVE PLC Questions And Answers | 2 | November 27th, 2004 10:12 AM |
