fault light on ML1400
leonlai
Jun 2011
WA
96
It was running for months, oneday fault light on, check and see:
Data File S2 - Errors Tab:
Fault Override At Powerup S:1/8 = 1
(the rest is 0)
Major Error S:6 = 34 h (A negative value for a timer accumulator...)
I did set Overflow Trap S:5/0 (U).
what was wrong ??
Thank for your reply,
what do you mean take active measures ??
All of Timer Preset are input by user throu PLC.
Does it mean by mistake user put negative preset timer so it cause the Error ??
Yes, either the user entry must be limited to prevent this or have the entry write to a standard integer then test it before moving it into the timer preset.
He is right on again!! Yes check the input in the plc first before moving value. or if direct change the hmi to not accept "bad" values lol just reread you response, now I sound like a parrot...lol
I apologize in advance for resurrecting the past.
This thread was the only result a quick forum search yielded.
I got called out to a simple machine and found the ML1000 faulted with major error 34.
Small program with only 13 timers.
The data table showed all acc values at 0. I went through and ck'd all the preset values at each timer instance.
all are set to positive values.
all the timer presets are static values and not stored in integer files. There is no hmi and the program doesn't do any math.
I was able to clear the fault and reset the machine. it has been operating for about 30 mins now.
I am just curious if the wealth of experience here on the forum would have any idea as to how this fault came about.
Hi Guys, I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but...
112
Hey Folks, I have a customer with an older machine that is controlled with a MicroLogix 1000. The machine just quit working. The power light is...
22
10,577
Hi , I have an Allen Bradley Powerflex 700 Inverter It has a green power light ( led ) and under that has a status Light ( led ) The...
2,256
Hello, I have a Micrologix 1200 1762-L24BXB PLC and as soon as I power it up with nothing connected to it, the power LED and the fault LED both...
3,748
Hi all, I am having an issue with a Micrologix 1500 1769-ECR. The PLC will not run and I’m unable to connect to diagnose the fault. When I power...
2,458
