1769-L24-QBFCB1 Embedded Counter Fault Reset (OK Light Flashing)
id10t_error
Oct 2017
California
99
Hi Guys,
I have a 1769-L24-QBFCB1 that has the OK light flashing on the embedded counter module. The manual states it is a resettable fault, but I can not find how to reset it. The fault occurred when changing a counter from "Pulse internal direction" to Encoder X4 while in run mode. Can this be reset without a power cycle? Thanks for all the help!
5370 Manual 1769-um021_-en-p.pdf
1769-HSC Manual 1769-um006_-en-p.pdf
EDIT: It's a BadModConfigUpdate from the manual.
I hope my description is clear. On a piece of equipment I have a 1769-L24-QBFC1B, 2 k300 drives, PV plus 600, and a PC connected to a 1763-US8T...
2,068
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
I have a CompactLogix 1769-L31 and need to communicate with it. I only have studio 5000 on my computer. However, when I try to start a new project...
398
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs...
256
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
482
