Allen Bradley Firmware flashing issues 1769-L24ER-BB1B
geniusintraining
Jun 2005
SC
8,278
I have a 1769-L24ER-BB1B and I am trying to flash it to 34xx, its flashing red and faulted, when I try to flash it I get a popup stating it needs to be reset because its not in the 'proper state' but I can go online because its has 1.005 loaded and its asking for the firmware before I can get on line... I have tried putting the switch to program and rebooting but still end up in the same spot
Any ideas?
Mark
There is a sticker on the front that has 34 or newer and that is the latest version I have
I tried ControlFlash Plus and through Logix Designer and both give me the same error
Failed to begin update
The target device is not in the proper mode to accept an update
Manually Reset module
Careful flashing other versions, there was this thread recently, the user said it allowed them to flash an older version but it went sideways:
Yep thats why I tried flashing 35, the sticker said 34 or higher, what is the little button on a L24er? I think it maybe a factory reset but I can find any procedure, I saw a youtube on a 5069 that used it and reset but its not working on a l24 and I dont have the display
Just an update... I had a friend tell me how to do a manual reset on the CPU (cycle power while holding down the button)
Same issues, after it rebooted (no flash card) still will not take the flash, very strange
No, I picked the first one.... so I just opened up another box and this one is working perfect, not sure what happen
I THINK... after we built it we installed the flashcard with the wrong firmware, this one said 34 or higher, I think the firmware on the old flash was 28, I am going to build a new flashcard with 34 and try to see if it will take, if not I will have an expensive door stop.
Good news, after making the new flashcard, looks like it was able to flash the CPU and now looks like they are both working, anyone have the same issue making a new SD that has the correct FW and letting load from the SD saves it
Thanks for everyones help!
Good day is there somewhere i can see the situation and compatibility regarding different firmware revisions. I have a 2711-K5A5, series H and...
216
Hello everyone. I am working on a rebuilt AB-Ultra series drive (1998) and the firmware for the drive is needed to test and use the drive. I would...
457
Hi, this is my very first thread. I am a PLC enthusiest and am setting up an AB compactlogix 1769-L35E controller with some relays at home to play...
3,094
Hello, I have several SLC-500 based systems. The user interfaces are PanelView 2711-TC1 touchscreens with firmware revision 3. I purchased a...
2,079
Dear team, I am trying to update the firmware of allenbradley panelview550 model 2711-K5A2 keypad type with previous firmware...
1,914
