Micrologix 1500 Solid Fault light
martin1
Apr 2008
Britan
43
Hi all,
I am having an issue with a Micrologix 1500 1769-ECR.
The PLC will not run and I’m unable to connect to diagnose the fault.
When I power cycle the PLC it goes straight into fault.
Any ideas?
93
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
923
Hello folks, Hope everyone is doing fine. I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500. 1. Is...
1,211
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,434
