Micrologix 1500 LSP
ElecTeam
Aug 2023
Egy
Good Day
i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc
I Order 1761-net-aic but don't know how to configure it to work as Modbus RTU.
could you help me with this issue? how to configure Micrologix 1500 LSP as modbus rtu
The MicroLogix 1500 can send ASCII, so if the message to be sent is simple and fairly stable beyond the value, it would be involved, but not impossible, to write code to send the register(s) as ASCII data, and then ignore the response. The most time-consuming coding effort would be implementing the CRC calculation in ladder, but it is certainly possible.
Another option might be an intermediate Modbus RTU Master device, that value(s) from the MicroLogix 1500 configured as a Modbus RTU Slave, and then writes those values to the target Modbus RTU Slave device.
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Hello, I want to use the RTC function files in my program to turn on a certain output at a certain time, but I am having trouble setting the...
3,935
Battery is bad. Broke + terminal removing battery. Does this unit have an EEPROM available for it? Currently we have to reload program every...
2,255
I apologize for this post as it may be a simple oversight on my part. I have 2 AB Micrologix 1500 LSP PLC's and 1 Micrologix 1510 LRP. I'm using...
6,057
Good morning Everyone, I replaced a micrologix 1500 1764-lsp processor this morning and downloaded the program, but when I try to put the...
3,613
