Micrologix 1500 LSP 1764
Seagullplayer
Aug 2005
Indiana
19
Battery is bad. Broke + terminal removing battery.
Does this unit have an EEPROM available for it?
Currently we have to reload program every time power is cycled.
I assume I can get by without a battery as long as I have an EEPROM?
I saw the memory module but it does not show an EEPROM.
Can the memory module we used that way? I thought it JUST expanded available program memory space?
The existing battery is bad, and the method of connection to the PLC board is broken.
I did attach leads to a new battery and plan to try and attach it to the board.
I also found a used PLC to install if the battery trick fails.
The EEPROM is inside the module.
The memory module can only be used to backup your program.
See chapter 6 for more on this procedure.
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
107
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
921
Hello, I want to use the RTC function files in my program to turn on a certain output at a certain time, but I am having trouble setting the...
3,935
I apologize for this post as it may be a simple oversight on my part. I have 2 AB Micrologix 1500 LSP PLC's and 1 Micrologix 1510 LRP. I'm using...
6,059
Good morning Everyone, I replaced a micrologix 1500 1764-lsp processor this morning and downloaded the program, but when I try to put the...
3,615
