micrologix 1500 with OMRON NS HMI
advmin
Mar 2023
Sheffield
59
Hello folks,
Hope everyone is doing fine.
I got an OMRON NS10-TVOOB-V2 hmi screen last day and planning to use it with Micrologix 1500.
1. Is it possible to connect the HMI in channel 1 of ML 1500 (RS 232)?
( In one of the manuals I saw CBL pmo2 cable is required to connect the HMI with the PLC, but that port ( channel 0) is used for communication with software.)
2. Is there any free software for the Omron HMI configuration and design?
cheers all !
Good Morning,
The Omron NS series will not connect to a Rockwell PLC.
Omron, Mitsubishi and Siemens can be connected.
Software is CX-Designer, there is no free version of this.
The Omron NB series would connect to Micrologix.
NB Designer software is a free download from Omron.
Hope this helps.
gtsuport
Thank you for your reply.
I made some research on this topic today. I came to see a pdf regarding the plc compatibility. I have attached the snippets from it for reference.
On page number 100 it's saying about the connection with Rockwell PLCS.
But not sure whether it's possible to connect the two together.
Please have a look.
cheers!
Sorry, I was looking in an old manual.
V092-E1-12 manual shows connection information for Rockwell in Chapter 9.
Shows all the information you should need to connect.
There is NO free software for the NS series.
Lite version of CX-One would be the least expensive option.
gtsuport
Thanks mate for your reply.
ya. it explains well about Omron's connection with different controllers.
thanks for your suggestion. I will try to get the Lite version then.
Cheers and have a great weekend.
82
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
106
Good Day i Have Micrologix 1500 LSP, and I want to get data from plc and send it through Modbus RTU slave; I have only ch0 on that plc I Order...
917
Good morning to all, I need to modify an existing PLC MIcrologix 1500 configured with a Modem on Channel 1 (DF1 Full Duplex) and an...
1,429
Hi to all, Unfortunatelly I can not provide any help with PLC but will do on some other forum for microcontrolers. I need help with PLC to panel...
1,596
