plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 10th, 2009, 12:37 AM   #1
gmst001
New Zealand
gmst001 is offline
Question Schneider M340 & Red Lion G3
Hi, I have to do a job with a Schneider / Modicon 340 PLC and was wondering if I can connect a Red Lion G306 to it. I can't find out much about it. Some Modbus arrangement maybe ?
Cheers, Grant
Old July 10th, 2009, 01:25 AM   #2
chud
South Africa
chud is offline
chud's Avatar
you get different m340 cpu's. bmx p341000, bmx p342000, p342010,p342020 all have normal onboard modbus port. if the red lion has a ethernet port i would go for a bmx p342020(onboard modbus and ethernet port) or p342030 (onboard ethernet and canopen) or optionally you can buy the cheapest m340 and get an extra NOE to use for comms with red lion.
Old July 10th, 2009, 02:18 AM   #3
chud
South Africa
chud is offline
chud's Avatar
i checked out the red lion and it supports modbus tcp/ip. so any m340 with an ethernet port should work fine
Old July 12th, 2009, 11:27 PM   #4
gmst001
New Zealand
gmst001 is offline
Thanks chud, I'll head down that path.
Old April 7th, 2010, 06:50 AM   #5
Chikus
United States
Chikus is offline
Tag addressing
Greetings.
I also have a G3 series Red Lion I want to use with an M340. Using either Crimson 2 or 3, when the Ethernet protocol is set to Modbus TCP/IP, the tag addressing is in standard Modicon format (0xxxx, 1xxxx, 4xxxx, etc.). Unfortunately the M340 follows the IEC61131 standard. Is it possible to address in the old Modicon format to read and write to the new format, i.e. %MW0 = 40001? ...or am I missing something?
Thanks for any input.
Old April 8th, 2010, 06:11 PM   #6
gmst001
New Zealand
gmst001 is offline
Yeah. That's what I discovered - the Redlion address of 40001 corresponds to the %MW0 address in the M340 and so on.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Red Lion G3 error - Compactflash Required Matthias von Zorn LIVE PLC Questions And Answers 10 February 22nd, 2008 01:57 PM
Red Lion G3 - Comms to ControlLogix CraigM1 LIVE PLC Questions And Answers 6 November 2nd, 2007 10:24 AM
Red Lion G3 ArikBY LIVE PLC Questions And Answers 9 July 30th, 2007 04:05 PM
I/O for Red Lion G3 kolyur LIVE PLC Questions And Answers 8 July 2nd, 2007 11:38 AM
Red Lion G3 HMI drawson LIVE PLC Questions And Answers 11 December 23rd, 2006 09:41 PM
