plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 19th, 2009, 08:26 AM   #1
kiran
Canada
kiran is offline
Differnce between Profinet and ethernet.
Could anybody tell me the difference between ethernet and profinet? Can I connect an ethernet device to profinet network directly?
This is my first project with siemens PLC.
Thanks,
Old November 19th, 2009, 09:04 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
The PN ports on an S7 PLC can be used for 'regular' ethernet connections. That includes programming with STEP7, and attaching panels and PC HMIs.
Regular ethernet devices can co-exist with Profinet IO Devices and IO Controllers on Profinet networks, as long as everything is consistently hooked up via Profinet switches.
__________________
Jesper
3 strikes and you're out
Old November 19th, 2009, 10:01 AM   #3
nonuke
Portugal
nonuke is offline
nonuke's Avatar
Taken from the Siemens Profinet Manual
PROFINET
(IEC 61158/61784)
The international standard uses Industrial Ethernet and allows
real-time communication all the way to the field level,
but also integrates the enterprise level. With the full utilization
of existing IT standards, PROFINET allows isochronous
motion control applications, efficient cross-manufacturer
engineering and high availability of machines and systems
on the Industrial Ethernet.
PROFINET supports distributed automation (and controllercontroller
communication) and it allows fail-safe applications
Old November 19th, 2009, 10:11 AM   #4
tim2
United States
tim2 is offline
You can look at this thread. I was asking a similar question and its got some good informatino in it.
http://plctalk.net/qanda/showthread....light=profinet
Old November 19th, 2009, 12:00 PM   #5
jemac25
United States
jemac25 is offline
Profinet uses the CIP Protocol Overhead Area of the
IEEE 802.3 Ethernet Message Frame to send process data.
This allows Profinet to send 1440 bytes of data per frame versus 500 bytes of data for a Standard Ethernet Frame.
This is approx. 3X data transfered per frame. Profinet can also send and recieve data directly to the application layer
without having to go through the IP and TCP/UDP transportation layers. What this basically means is Profinet sends more data much faster than Standard Ethernet but it can still be handled with off the shelf routers and network switches.
Jemac
Old November 19th, 2009, 05:18 PM   #6
kiran
Canada
kiran is offline
Thanks a bunch.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Distributed IO control over Ethernet - Siemens Profinet g18c LIVE PLC Questions And Answers 5 June 30th, 2014 05:39 PM
Profinet and Ethernet networks tim2 LIVE PLC Questions And Answers 4 November 11th, 2009 12:52 PM
profinet / ethernet without switch Combo LIVE PLC Questions And Answers 11 June 23rd, 2008 01:20 PM
Industrial ethernet & Profinet difference Nilesh Sinha LIVE PLC Questions And Answers 1 October 17th, 2005 06:19 AM
Profi-bus or Ethernet Shailesh10 LIVE PLC Questions And Answers 1 December 31st, 2003 01:19 AM
