Step 7 Puzzle
L D[AR2P#0.0]
Nov 2006
UK
6,702
The following Step7 (V5.4) project has been run using PLCSIM and causes Q0.0 to flash.
Which block(s) are responsible for the flashing of Q0.0 ?
(Answers by PM please)
There is more to discover. Open OB35 and save it (thus removing the hidden code) then download OB35....
Hi
Have worked out how expose the hidden code. But still have no idea how it is hidden in the first place??
Jon
Does this also work when you uploaded the blocks?
EDIT: yay I gave L D more info for nice puzzles.... :D
Lol…every time I’ve worked on a S7 program I thought someone was hiding code…now I know who it was.
Hi LD
If the project is opened online and FC1 is deleted out, online, the OB35 is opened and Call, BLD 7, BLD 8 and End Call are commented out and the project is then up loaded the hidden code can then be seen off line. OB35 off line and online do not now match. Online shows the commented out code and as replicated it uncommented?? Down loading OB35 gets rid of the replicated code and still allows the code to function.
Still not sure why there is a difference in downloading OB35 when the block is open as opposed to downloading form S7 Manager. Also looking at the help file for BLD how did you know to use 7 & 8??
Jon
Here's a gentle Step 7 puzzle that flashes Q0.0 when using PLCSIM. There are two mechanisms for flashing Q0.0 The first (trivial) method controls...
2,344
The following Step 7 project has been run using PLCSIM and contains code that flashes Q0.0 The Project is based on a UK board game called Cluedo...
4,601
Four rabbits start at the four corners of a 32x32m field. A farmer fires his gun and each rabbit starts running in an anti-clockwise direction and...
25
10,298
Can you analyse the attached painting to determine the address of the Q output that flashes ?
18
8,496
After last month's minimalist effort - I've gone for a slightly bigger implementation this time. I'm posting all but one of the spanned zips ahead...
17
4,230
