plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 15th, 2010, 05:01 AM   #1
DeepThought
United Kingdom
DeepThought is offline
DeepThought's Avatar
Fancy Exclamation S7 Ethernet $ Sick CLV 650 Barcode Reader
Hi Guys,
Ethernet on siemens is new to me so i am hoping someone can help me with this.
I have a S7 315 with a 343-1 and i need to connect a sick CLV 650 bar code reader to it. What i need to know is how to write the software for the connections and send an Ascii character to the bar code reader and recieve the data from the reader.
Thanks in advance
Old November 15th, 2010, 05:15 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Problem is that the SICK scanner "supports TCP/IP", but that does not in itself say very much. It also supports Ethernet/IP, but that will work with an AB PLC, not a Siemens PLC.
I would seriously consider a barcode scanner that can be integrated directly with an S7 PLC without you having to use too much time with figuring out how to get the SICK scanner to work with an S7.
A short search on the www revealed this scanner that has a Profinet interface:
http://www.leuze.de/press/data/bcl548i/bcl548i_en.html
There may be other possibilities with Profibus or Profinet.
For the Leuze scanner with PN, the easiest would be to ditch the 315+CP343-1 for a 315-2PNDP with an integrated PN port. Will be better and same price anyway.
__________________
Jesper
3 strikes and you're out
Old November 15th, 2010, 05:53 AM   #3
DeepThought
United Kingdom
Hi JesperMP, Thanks for tyhe reply,
I have no choice in the scanner type that is already in place I need to communicate with this in whatever way i can whether it be tcp or ethernet
regards
Old November 15th, 2010, 05:59 AM   #4
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Can you make the guy who purchased the barcode scanner figure it out for you ?
Sick have some gateway modules to interface to Profibus.
I would go that way if I were you.
http://www.sick.com/group/EN/home/pr...echnology.aspx
__________________
Jesper
Old November 16th, 2010, 01:52 AM   #5
hill831017
China
hill831017 is offline
For sure you will need one gate way to exchange data from CLV to your PLC(Ethernet and MPI capable only?),CLV itself can't work alone. And also later for configuring scanner by CLV-Setup, gate way also necessary.
Old November 16th, 2010, 03:57 AM   #6
DeepThought
United Kingdom
Thanks after some thought I have thought about connecting it through my HMI (19" PC 677Touch) this may provide my gateway so i can pass the data onto the PLC. Once solved i will re-post what i did.
In the mean time further answers are appreciated.
Old February 13th, 2015, 01:13 PM   #7
tim stokes
United Kingdom
tim stokes is offline
Sick supports profiinet profibus Ethernet IP eterhcat......lots more
Hi best solution is to contact the sick office in your country , they will give you function blocks and EDS GSD files and help documents
To my knowledge there isn't a field us that SICK can't support and the tech support is world wide.
I don't look at this page often ! But you can contact info@sick.co.uk for more details and someone will contact you . Or ask for me
Or Google SICK subsidiary in your country
Tim
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens S7 Ethernet Problem S7Guy LIVE PLC Questions And Answers 7 February 4th, 2008 02:51 PM
Barcode reader - OPC sapoleon LIVE PLC Questions And Answers 5 December 20th, 2006 12:04 AM
Siemens S7 ethernet protocol fzhang LIVE PLC Questions And Answers 3 May 19th, 2004 12:06 PM
S7 Ethernet protocol ?? RussB LIVE PLC Questions And Answers 15 December 19th, 2003 09:26 AM
Ethernet Barcode Reader to SLC505 chriskei LIVE PLC Questions And Answers 2 July 9th, 2002 01:17 PM
