plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 25th, 2011, 03:07 PM   #1
jcole1
United States
jcole1 is offline
gsv and ssv instruction
Hello guys and gals.
I have a processor instruction being used in one of my compactlogix called GET SYSTEM VALUE with the following info:
Class Name-ControllerDevice
Instance Name-
Attribute Name-Status
Dest-Processor_Status
I do not understand the field names (class, instance, attribute) or where controllerdevice and status come from. Its obvious something is being put in a tag called processor status which is an int data type but I can not figure out the purpose or where the data is coming from.
Could somebody enlighten me?
THanks for the replies.
Old May 25th, 2011, 03:16 PM   #2
widelto
Colombia
widelto is offline
widelto's Avatar
Please download manual 1756-RM003 from ab.com web page, in chapter 4 you will find a good explanation on GSV and SSV
__________________
My two cents.
Old May 25th, 2011, 03:29 PM   #3
Ron Beaufort
United States
Ron Beaufort is offline
Ron Beaufort's Avatar
regarding the following GSV terms:
Class
Instance
Attribute
turns out that they're basically just "blanks" that you may (or may not) have to fill in to get the GSV or SSV to work ...
secret handshake: don't worry about the differences between the three terms ... just click and select whatever you need from the "pull down" menus available for each ...
and here's a "general idea" post that might be helpful ...
http://www.plctalk.net/qanda/showthr...31&postcount=4
__________________
2-B ?
Best regards, ----+----] [----+------------( )----
Ron | |
PLC Training Boot Camp | 2-B |
I once was lost, but now am found, was blind, but now I see.
Old May 25th, 2011, 04:04 PM   #4
Craig Spinharney
United States
Craig Spinharney is offline
Best way to look at the Class, Instance and Attribute fields...
Class - What am I interested in?
A Task? A Module? A routine? etc....
Instance - Which one?
Which task? Which module? Which Routine? etc....
Attribute - What do I want to change(SSV)/know(GSV) about it?
Last Scan Time? Fault Code? Inhibit Flag?
etc...
Destination holds the tag to store the data I/m asking for (GSV) or the datas I want to send to the controllers status (SSV).
Another analogy.
Class - What am I intrested in?
Answer: The houses on Maple Street.
Instance - Which house?
Answer: 3712 Maples Street.
Attribute - What do I want to know about it?
Answer: The color of the house.
Destination contents: Green
Some of the Class choices (CONTROLLER, WALLCLOCKTIME, SERIALPORT) will result in no choice for Instance because there can only be one CONTROLLER, WALLCLOCKTIME, etc.
Old May 26th, 2011, 07:15 AM   #5
daba
United Kingdom
daba is offline
daba's Avatar
All the info for GSV and SSV is built into the RSLogix5000 help system.
Simply click on the instruction name (GSV or SSV) and hit "F1".
The first page shows general info about GSV and SSV (usage, examples etc.). Scroll to the bottom of this first page and see the links for "GSV/SSV Objects". Follw these links to get detailed data on what the instructions are addressing in the System Value area.
HTH
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
