1761-CBL-PM02 / Optical Isolator
Peacemaker
Feb 2004
22
Recently I bought a communication cable (1761-CBL-PM02) for MicroLogix controllers but there is Caution Tag on the cable package saying "An optical isolator is recommended between the controller and your programming device". I would like to know what this optical isolator is and whether I should use it. Any advice on this would be much appreciated.
I know this thread is old but I am interested in the answer to the original post.
I am new to plc's and just bought rslogix 500 and I'm going to buy a micrologix 1000 to play around with.
A couple of quick questions:
1.I was searching for a 1761-CBL-PM02 cable on ebay and all I found were the non-factory made cables.Are these safe to buy or should I go with the more expensive Allen-Bradley cable?
2.Regarding the opto-isolator.Is there a part number you guys can give me for this.I dont want to fry my new laptop.
Thank you for the help
Thanks for the plug Mickey...
I am going to start selling isolators (I have about 50) but I have sent one to Dave (504bloke) to test for me before I start selling them
I think these are used primarily in the UK?? due to the voltages? I have never used one and don't think I will have the need... but I may be wrong
As far as my cables and mrplc (Chris) I test mine 100% before I ship them, I am sure Chris also does.
On the Micro's there is 24vdc on one of the pin, so if it was not made correct then you could smoke you com port, but this is why we test them.
Also if you are going to just play around then you may want to read this http://www.plctalk.net/qanda/showthread.php?t=33740&highlight=free+rslogix+500 it may save you a few bucks
Mark
never need one when programing MicroLogix but i have used them few times on PCs on the shop floor doing data logging etc. it resolved issues of PC freezing when port is in use (serial ports on some motherboards are very sensitive, specially newer ones where signal levels are lower). this is a shame and it should have been addressed by computer makers which is not likely to happen now when RS232 presence is fading away.
Its still under test :)
The guy i gave it too has blown up 2 laptop serial ports so i think it will have a good test :) I will hurry him up next week !
Needed here when connected to an ssd drive 232 port as its not isolated.
The manual for the 1761-NET-AIC shows connecting a PC to DH485 network with a 1761-PM-02 cable. Is this done using a DF1 driver set to...
1,060
Is there a cable that I can buy that is the equivalent of the 1761-CBL-PM02 plus a null modem and gender changer? I have some new radio modems...
17
5,941
So, I need a RS485 Modbus slave to do some testing. Well, since I don't have any RS485 Modbus Slave sitting around but does have a Micrologix...
3,204
Good day, I have a little problem with connected a PLC micro 850 Allen Bradley with a HMI C200. Already connected PLC with ethernet cable in my...
1,406
Hi everyone! I am new to the site, I found it while trying to find help getting my driver set up. I am a Mechatronics student, and we are now...
3,407
