plc storereviewsdownloads
Go Back - Interactive Q & A > - Interactive Q & A > LIVE PLC Questions And Answers
PLC training tools sale
Thread Tools Display Modes
Old June 13th, 2013, 02:12 AM   #1
suppaman is offline
Indirect addressing with WinCC Flexible
Hello everyone.
I'm having some problem with indirect addressing in WinCC Flexible RT (PC-based)
I've a DB structured as below: an array of 300element of UDT.
The udt consist in two variables:
Code: INT
Description: STRING[30]
So it's something similar to a table.
In this table, i've to do some operation like add elements, sorting by "code", delete and compact, modify.
On the plc side, there's no problem, i've already written all the function that i needed.
The difficult part is on HMI side.
I've to create a page to view the table. But beacause of the amount of the elements, i would like to have a view in a single page of at least 10 (maybe 20 is better) elements, so 2 columns (one for the code, the other for the description) and lets say 10row.
Then, with two button prev and next i can navigate into the DB Table's elements.
As i'm not an expert with indirect addressing and script, the only way i've got the things working it's like below:
I've create 10 fields "code".
Field1 contain variable Code_1, that point to DBxxx.DBW[code_index_01] (with multiplex address mode), Field2 contain Code_2 that point to DBxxx.DBW[code_index_02] and so on..
A default start value of the internal variables code_index_yy is set, so the first time i run the RT i've the indexes pointin g to the first ten elements.
Then when i press "next" button, it runs a script wich simple increments the variables code_index_yy to point to the next ten elements
But in my opinion is not a very elegant solution.
This HMI communicate with 3 different PLCs, each one have its own DB, so i've to repeat the variable for each one...
Maybe anyone of you have other ideas on how to do that? With a different approch maybe?
I've also attached some images, maybe with these it's easy to understand..
Maybe my explanation is not very clear, but i hope you'll understand the problem.
Thanks a lot for your support.
Old June 13th, 2013, 05:54 AM   #2
RMA is offline
RMA's Avatar
For this sort of thing I always do it the other way round now - create a single display page for the HMI and resrve a space in the PLC memory for this. I then map the data as required in the PLC - much easier than trying to do it in the HMI and you save a load of tags as well (although I believe that's no longer such a problem with WinCC Flex as it was with ProTool).
Old June 13th, 2013, 10:41 AM   #3
United Kingdom
uptown47 is offline
I'm with Roy on this one. A datablock in the PLC and then the data is mapped in via an Int in the PLC which is incremented or decremented by your navigation buttons indirectly.
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Citect Vs WinCC - Long Doug_Adam LIVE PLC Questions And Answers 22 October 3rd, 2014 12:56 PM
Siemens SIMATIC WinCC flexible 2008 Advanced - Installation Fails Saulo35 LIVE PLC Questions And Answers 4 October 7th, 2013 07:14 AM
Why cant OPs state the "Flexible" in WinCC Flexible ? JesperMP LIVE PLC Questions And Answers 0 August 5th, 2008 01:41 AM
WinCC Flexible Quirks tvey LIVE PLC Questions And Answers 5 May 3rd, 2007 05:57 AM
Simatic Wincc Flexible 2004 -->2005 STL??? LIVE PLC Questions And Answers 8 August 29th, 2006 05:42 AM
