plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 1st, 2013, 03:15 AM   #1
Tresancos
Spain
Tresancos is offline
Extreme temperature conditions
Hi!
I have a project where the PLC works in extreme atmospheres, such as -30C . Before install it the PLC has to been tested in a climate chamber at -40C. I can't find companies that supplies PLC to this conditions.
Which PLCs could be installed in such conditions?
Thanks for the answer
Old July 1st, 2013, 05:12 AM   #2
shooter
Netherlands
shooter is offline
shooter's Avatar
find companies with a marine approval like DNV, LLoyds, GL etc.
i use WAGO PLC (with Codesys) they do have approval, these low temps are not the biggest problem, the higher ones are.
operation is from -20 to +60
extended range is possible, however there will always be some heat by the PLC, so a little heating in an insulated box should be possible.
The biggest problem with low temps are the capacitors mounted, the rest is no big issue.
Another possibility is to make yourself a small board wit a mega328 very simple no external parts needed. see arduino for examples)
__________________
shooter@home.nl
skype shooter paul.deelen
Computer Shooter
Paul Deelen
J. Wassenaerstraat 29
NL 5224 GG 's-Hertogenbosch
+31653300739
Old July 1st, 2013, 07:03 AM   #3
BryanG
United Kingdom
BryanG is offline
Siemens have extended temperature range versions of their PLCs under the name of SIPLUS. The info certainly seems to say that -40C is do-able.
https://www.automation.siemens.com/m.../default.aspx#
https://www.automation.siemens.com/m...df?HTTPS=REDIR
Old July 2nd, 2013, 04:04 AM   #4
GeoffC
Australia
GeoffC is offline
GeoffC's Avatar
Have a look at the Twido Extreme from Schneider
http://www.global-download.schneider-electric.com/85257578007E5C8A/all/0359D15C740CCFEA88257577000C0742/$File/35013462_k01_000_05.pdf
from the manual
Environment Characteristics
The operating environmental characteristics are as follows:
Characteristic Description
Operating temperature range -40C to +110C (-40F to +230F)
__________________
Geoff C
______________________________________
Old July 19th, 2013, 02:16 PM   #5
Karsten
Denmark
Karsten is offline
http://www.ifm.com/ifmuk/web/pinfo080_020_040.htm
Old July 20th, 2013, 12:12 AM   #6
seppoalanen
Finland
seppoalanen is offline
seppoalanen's Avatar
-30 is normal tempereture here in winter time. Therefore we are heating houses, as well PLC-Cubicles. Inside The Cubicle we can use insulating material as polyurethane plate in door and walls.
Rittal have suitable heaters and thermostat that you can enable voltage for PLC etc. when temperature is enough warm inside. Remember humidity also.
Then after, you can use everything you like.
Old July 20th, 2013, 10:28 AM   #7
Highland Controls
United States
Highland Controls is offline
The ABB AC500 XC(Extreme Conditions) PLC will meet those requirements.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
M a student n need a help to develop a chemical plant as mentioned---- komal.sukre LIVE PLC Questions And Answers 15 September 27th, 2012 10:49 AM
hmi for extreme conditions, connectable to Siemens plc Kataeb LIVE PLC Questions And Answers 1 June 29th, 2012 05:45 AM
HVAC Temperature Sensor Display and Set Points wwsmith LIVE PLC Questions And Answers 7 May 10th, 2010 06:42 PM
RS5000 PIDE w/2 TC's & SRTP??? Geared LIVE PLC Questions And Answers 29 November 5th, 2005 08:08 PM
Simulator, Simulation, Shadow Code Terry Woods LIVE PLC Questions And Answers 1 January 2nd, 2005 01:40 PM
