s7 1200 multiple mb client blocks
pauly
May 2002
South Wales,U.k
244
I am looking for some assistance with Modbus tcp/ip to read and write data to a third party plc. I can read data with one mb client instruction but when I add a second mb client instruction to write data, comms stops with the read instruction staying at busy and no data can be read. Every example I see describes modbus tcp/ip connections between 2 s7 1200 controllers. This makes sense because the two client instructions for read and write have equivalent server instructions with different ip port numbers. If I have 2 client blocks which I want to use 1 to read and 1 to write data to the same I.p address, how can I assign different ip ports? This is a connection to a third *party plc.Any help would be great.
Each MB Client requires separate Connection ID.
You Can always sequence MB Client calls to save Conn ID :).
Program structure - s7-1200 MODBUS RTU Master with multiple slaves & multiple registe I'm having problem to make a appropriate structure of my...
11,331
I currently have three S7-1214C CPU's running multiple lines of presses. Our company is trying to avoid using any HMI's, to display information...
1,915
I have written my own dll (wrapping parts of libnodave) to communicate with a 1214 S7-1200 PLC via the builtin ethernet port. It is working fine...
4,446
I am dealing with a machine shop using several (10-12) AB Micrologix 1200's on their machines. They are using 1761-NET-AIC DH485 for...
4,460
Guys, I have posted 2 programs that are identical, other than I have added multiple instances of the same S:4/xx flags in the same routines. I am...
3,020
