SNK
Guys, I have posted 2 programs that are identical, other than I have added multiple instances of the same S:4/xx flags in the same routines.
I am writing code to ramp and decelerate VFDs, and I am looking at using only a few ramp rates. I have to complete this task in the ML1200, not the drive.
Ladder 5 is where the changes are.
If you run the logic in Program called MAR_EXHAUST_SINGLE_MTR, the ramping works perfectly.
If you run the logic in Program called MAR_EXHAUST_TRIPLE_MTR, the Deceleration ramping is almost instantanious, on all timer flags.
I am completely worn out trying to find out what is causing this problem,
So I as the experts.....what is going on?
I am using an ML1200
RSLogix500 version 7.00
