The problem about ML1200 1762-L40BWA
xiaoqiang83
Jul 2023
China
Hello everybody and master,I met a problem about ML1200.It is described as below:
1,When i got this PLC,The FAULT light is lighting, My computer can successfully connect it via DF1;
2,I decided to update the firmware and swap the PLC,Firstly i want to update it to Version 14,But unforunately not successful,It appear that the error message as picture shown--"When update v14,The error message".
3,I searched and found a master mentioned that maybe we need to update it via a lower version control flash, Then i use control flash v11 can successfully update the firmware to V14,But when i changed it running mode, The fault light is lighting and the error message is that "Base hardware is fault or the base hardware is incompatible with OS".S6=Bh
If someone can help to solve this problem or give some suggestion,I am so appreciate that. Thanks
Is the FAULT indicator a steady red color, or flashing ?
A steady red indicator means that the controller cannot be recovered with software changes. Flashing red indicates an error in the user program.
It is entirely possible that you purchased a damaged or defective controller, and re-loading the firmware will not allow it to function correctly.
Hi Ken, Thanks, The Fault indicator is red flashing.
I can upload the empty program to the PLC,After i change it to running mode, The fault is appeared again. S:6=Bh
I am so sorry that i forget to upload the message picture. This topic is my first time to learn related knowledge on PLCtalk.
When update V14,The error message.jpg Base hardware fault or base hardware incompatible with OS.jpg
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
718
I am very new to AB PLC's we have a ML1200(14 inputs/10 outputs B series) we are trying to connect it with RSLogix500 (4.50) software thro RSLinx...
2,698
I had to make a small program change today and attempted to download my updated program to the ML1200. While downloading, it got to the point...
1,669
On all pages of my project i have a lot of information, texts and details that should not not be shown. I can remove them for each part apart from...
40
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
173
