Intresting ML1200 problem..
ELake20
Aug 2003
N. Michigan
271
I had to make a small program change today and attempted to download my updated program to the ML1200. While downloading, it got to the point where it was writing function files and then it hung up there and the Power/Run/Comm0 lights flickered 3 times and the PLC was taken out of run mode. While it was out of run mode, I was unable to communicate with it. I then cycled the power, and the PLC then faulted, saying "no user program" or something of the sorts..In order to go online to clear the fault I had to create a new use file since my previous download had failed. I attempted 6-7 times.
Anyway, replaced the controller and the fixture is back up and running, just wondering if anybody else has experienced something as odd as that...
I've searched and searched.
I've never seen that, but I did have a ML1200 once that would just switch from run to program mode for some reason about once every three or four months.
Hey all! Long time reader, first time poster! I have an EA9-T7CL and an MicroLogix 1200 connected via DF1. I'm all good and got everything mostly...
660
Hi every master,Recently i met a fault about 1762-L40BWA 1,When i get the PLC, The Fault light is lighting, I am not remember the fault message,I...
722
Hello everybody and master,I met a problem about ML1200.It is described as below: 1,When i got this PLC,The FAULT light is lighting, My computer...
1,118
I had planned to use PTO instructions to control a servo motor, single axis only. We have a ML1200 BWA model. According to the ML1200 manual...
3,499
I am using Modbus to read 36 registers from a ML1200. 2 of those registers are suppose to be L11 data and 2 of the registers are F8 data. Long...
1,404
