Loop Calibrator
PLC Pie Guy
Jun 2013
Halifax
1,144
Good morning all.
I am looking to purchase a loop calibrator.
I am looking at a particular model with different options but I have one question.
What is the difference between simulating and generating when referring to Ma and 0 - 24 VDC?
We sell this one and for the price its a great deal, we have sold a lot and have had very good feedback from them
http://www.plccable.com/milliamp-current-volt-generator-4-20-ma-0-10-vdc-epro-with-case-leads/
If you are just looking to read we have a Fluke 771 and 772 if your going to generate the signal then the 707 is a good model but I am out
Not sure if they go to 24vdc, when I needed to go to 24 I used a variable transformer
To me simulating and generating are the same
I love my fluke 772. pricey but worth it. The clamp is nice for troubleshooting without breaking the loop
The 725 is awesome but it doesn't have a milliamp clamp meter. .. Also I prefer the seperate ones for temperature and milliamps because A. If 1 fails or needs sent in for calibration I still have the other meters. B. simpler menus
A little speculative here, but I think the manufacturer is using simulate for a two-wire device where the 4-20 mA signal is loop powered external to the calibrator. Generate would be using the calibrator's own power to source the 4-20 mA signal the way a four wire device does.
I think Tom is right, many calibrators have different modes:
Read 4..20 mA - ext 24 VDC
Read 4..20 mA - while supplying 24 VDC
Simulate 4..20 mA - ext 24 VDC
Simulate 4..20 mA - while supplying 24 VDC
4..20 mA often is 0..22 mA
If you need an actual calibrator, and not just a test device, you will have to spend the money to get something traceable and calibratable.
If you just need a test device that is generally accurate, almost any meter that has the functionality you want will do.
+1 for the Fluke 789, can read Ma without breaking the loop.
read, simulate, source, step, + volt ac/dc, ohms, its got it all in one package.
Cost some $$$ but well worth it.
a simulator only has a control in it, thus works without battery.
in a generator a battery is added to the loop, So you wont need the power supply, and can control a sensor without any connection.
Good Evening , I’m getting ready to integrate a Mettler Toledo IND 570 into a ControlLogix PLC , Analog 4-20 ma input card 1756-IF16 . I’m...
2,306
Hi All, I'm looking for an analog looop calibrator/trobuleshooter for current/voltage. There are so many kinds and I have no experience with...
23
5,815
Hello, I'm confused today. I have a pump controller that has it's own 24vdc supply and takes a 4-20ma input from a level sensor to drive a pump...
4,513
One of our Altek 334A's bit the dust and we need to buy a new loop calibrator of some kind. I'm open to suggestions. This Altek was perfect for...
2,201
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
369
