TIA Portal - it must be an obvious mistake...
DLMUK
Jun 2013
Southampton
311
I am having an issue downloading to my HMI from my PC. It has been working fine for the last 2 weeks but it must have the Monday morning feeling...
When I try to download the "Extended download to device" box pops up, I press start search and it detects my HMI, if I press the Flash LED then the screen flashes.
When I try and download my project to the HMI I get:
Extended Download to Device (0132:000002)
Connection Failed
The selected online target could not be reached
I have done all the usual, checked my IP addresses, no conflicts.
Any other obvious things to try before I put a screwdriver through screen? o_Oo_O
Usually the connections are pretty solid.
Have experienced problems like this a few times. Closing and restarting the software or just restarting has fixed glitches like this most of the time.
Dear DLMUK
I have the same problem.
I have installed Tia Portal V13 Sp1 under Win 7 ultimate 64 bits.
Can you explain how did you do that:
Sorted now - no idea what caused it but I deleted the PN/IE connections on TIA and setup again.
Thanks for your help
Dear DLMUK
hi - sorry but as my post said, I don't know what caused it.
I went on the project under "Devices and Networks" deleted the connection between the PLC and the HMI, and then set it up again. Did the job.
I solved the issue!!
Just installed the "Update 8 of Tia Portal V13 SP1" and then It full worked!!
247
Hi guys , I'm new with Allen Bradley, but I have experience with Tia portal (s7 1200 ,s7 1500) I want to convert my project from Tia portal to...
203
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
167
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
310
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
