11 byte's, where are the FALSE bit's (S7)
userxyz
May 2002
any
2,768
I have 11 byte's with bits. It's from a light curtain.
When beams are interrupted, those bit's are high.
What I wanna detect is: gaps.
When 5 byte's have all TRU bit's, then we get 5 byte's with the value 255. If there are more then 2 bits False in Byte 3 for example, then I need an alarm. Anyone has an idea how to write this?
hmm
Well,
In a bunch of byte's all bit's are true. But, if there are more then 2 bit's False in all these byte's, an alarm needs to be generated.
L D[AR2 said:
An example is not good enough. Specify the functionality you require.
PIB256 = First Interrupted Beam
PIB257 = Last Interrupted Beam
So, I have this info.
You can seen the bit's that are interrupted in the byte's PIB263 264 265 in this VAT.
When more then 2 bit's between beam PIB256 and PIB257 are false, then an alarm needs to be generated..
crazy
This is crazy, more simple in SCL ?
I'll try to understand your SCL code, but it's kinda hard to understand (again)
L D[AR2 said:
Here you go. I'll leave the alarm processing for you to add.
Not really that hard.
Take some pen and paper, enter random values in variables and then work it out on paper.
Way easier to understand what he's doing.
Yes you can use the PLCSIM and online view, but with pen and paper you need to think about whats happening, not only see what happened.
Here you go in SCL:
Code:
FUNCTION FC888: int
VAR_INPUT
iOffset:INT;
END_VAR
VAR_TEMP
iLoop:INT;
iBitOffCount:INT;
byData:ARRAY[1..11] OF BYTE;
bData AT byData: ARRAY[1..88] OF BOOL;
byMore:BYTE;
END_VAR
  FOR iLoop:= 1 TO 11 BY 1 DO
	byData[iLoop]:=PIB[iOffset+iLoop-1];
  END_FOR;
  iBitOffCount:=0;
  FOR iLoop:= 1 TO 88 BY 1 DO
	IF NOT bData[iLoop] THEN iBitOffCount:=iBitOffCount + 1; END_IF;
  END_FOR;
FC888:=iBitOffCount;
END_FUNCTION
bzzz
Tried that, don't understand, grmzz
Isn't it easier in SCL ?
I have something else in mind (maybe too basic for you guys):
For i:= 1 to 11 do
if byte < 255 then
if byte <> 254 and <> 253 and <> 251 and <> 247 and <> 239 and <> 223 and <> 191 and <> 127 then
Alarm:= TRUE;
end_if
end_if
end for
hmm
It's more understandable, but, still need to analyse
I dont understand this line:
L D[AR2 said:
Here you go in SCL:
Code:
FUNCTION FC888: int
VAR_INPUT
iOffset:INT;
END_VAR
VAR_TEMP
iLoop:INT;
iBitOffCount:INT;
byMore:BYTE;
END_VAR
END_FOR;
iBitOffCount:=0;
END_FOR;
END_FUNCTION
Okay
Okay,
I will give it a shot...
euhm:
Okay, you place all the PIB data in tempbyte's.
Then you reset the iBitOffCounter.
Then you do a loop, 88 bits, so, 88 shifts of 1 step, checking each bit if it's low. If low, then you count up by 1.
The last line = don't understand.
Okay, you count the bits, but...
What I need is, an alarm when 2 or 3 beams (let's call it a gap) next to each other are LOW/FALSE. So it's allmost correct, but not yet.
FC888 is a function that returns an INT, this is how you assign an INT to the return value.
Code:
Our system utilises INPUT_BYTE to capture NMEA0183 ASCII stream which sends data to the NOM multiple times a second. The NOM module can either be...
402
Hello everyone, friends. I need help with something. I want to read and change Bit and Byte numbers via HMI. I found a code snippet for this as...
18
3,065
Hello everyone :) I just want to start with learning PLC programming, so I need advice. I have SIMATIC S7-1200, CPU with integrated memory...
945
I have a C-More HMI that changes my PLC String from "Machine Status" to "aMhcni etStasu" . There is an option with other objects that have string...
3,498
Hello I have got a problem with positive edge from "system clock memory byte" in Tia Portal. I would like to change byte"system clock memory"...
27
3,653
