1151 Smart Pressure Transmitter to a analog input
adamp
Mar 2013
newfoundland
Ive been trying to wire a 1151 smart pressure transmitter into a analog input card (1769-IF4) to display a range of 0-17 inches of water. Im using Rslogix 500 with a 4-20 mA signal. Cant seem to get a proper reading to display back to the screen. When i hooked a loop calibrater up to the transmitter it worked fine. Any feed back on this problem would be appreciated!
The 1151 is a loop powered transmitter. Can you give us a drawing of how you wired it?
And post your program ( zip it first).
Ive wired it several different ways. Some displaying the 4993 minimum valuse and some some displaying the max value. One way displayed a value of around 11000 at around 8mA but wounldnt allow it to be zero or spanned.
Hi there! I'm trying to set-up the communication between a E1151 HMI and a FX3G-60M PLC via a FX3-485-BD module but can't get it working...
1,590
Good Day Folks, We have a project where we are using a Mitsubishi E1151 HMI as the front end of a PLC controlled ESD system. I was pleasently...
4,739
The ControlLogix uses TAGs instead of I/O addressing to do ladder logic. My HMI software does not support TAG addressing. Can I change the A-B to...
1,845
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
176
I HAVE SMART TOUCH MS-60T-Pe MITSUBISHI HMI BUT I CANT FIND A SOFTWARE TO EDITE AND DOWNLOAD A PROGRAM IN IT.......CAN ANYONE HELP PLEASE!
88
