I have problem with one of axis in 1394 GMC servo system. I've two axis configured, first one was configured without any problems, but I can't configure the second one.
Marker Test is ok. During Motor/Encoder test servomotor doesn't make distance inserted in Test Increment window, it makes moves in both direction making weird noises, but information after test says it's OK. Tuning gains stops at 50 % after little movement with information that "Axis fault occured. Please examine and clear fault before reexecting the test" but there isn't any fault in Axis system variables.
I checked all of the setings for second axis and they are same like in the first one. I also checked DC bus connection and it seems ok. I changed feedback cable betwen axis and situation doesn't change. Any idea? Yesterday when I was testing the system everythnig seems OK.
Best regards,
Matt
Best regards,
Matt
