1746-NT8 have problem
huynt
Nov 2004
106
dear all.
Now, I use 1746-NT8, use K-type sensor and i config use oC. Some time 1746-NT8 display temperature 1370oC, but realtemp is 230oC. It have with all channel of module.Status led of module is OK. Have problem with 1746-NT8?.
Thanks.
Usually when a thermocouple card reads high scale like that, it's because of faulty wiring. TC wiring is critical, every problem I've ever had was due to a loose, corroded or improperly connected wiring termination. If you read up on the maitenance recommendations from the TC supplier, you will find that the wiring should be checked on a routine basis, this is often iqnored. That's one of the reasons's I seldom use TC's. I prefer RTD's, much more robust, and require very little maintenance.
Dear all.
I replace other NT8. Temperature is OK. Can old NT8 failed. I can repair that NT8, What component can fault?.
Thanks.
We're trying to help a customer with a SLC that originally had a 1746-NT4 thermocouple input card and apparently it failed so they bought a...
2,151
So i have a 1746-NT8 thermocouple for a conveyor furnace that is causing some problems. When the CPU is in run mode the channel 6 LED flashes, but...
1,613
Hi all, I am messing with an existing system that is operated with a PLC5-60. The system has remote I/O with the 1771-ASB module. The system...
3,128
Hey I need some help with a 1746-nt8 card. How does i get my temperatur reading? I am used to SCP a 4-20mA signal but I have never used a...
1,659
I've programmed alot of our AB SLC 500's and now I need to install a T/C (1746-NT8) card for measuring bearing temperature on our conveyors. Never...
1,997
