1746-ob16 problem
cornbread
Feb 2007
madison, indiana
407
Replacing a PLC with a SLC 500, we had a problem with a 1746-OB16. During checkout we found a loose wire on the DC comm to this card, once lifted every output on the card went on. Note: the outputs in this case are SS relays in motor starters. Note: the ouput LED did not change state just the outputs went high. Has anyone else seen this, is there a fix other than making sure the wire is secured?
The outputs all went ON, and actually energized the relays on the starters?
If so, I'd think initially that you need more loading across the outputs. Example: Put a half-watt, 1200 ohm resistor directly across each SS Relay input to common.
SS Relays don't need a lot to drive them, so without a common on the output module, the outputs may have floated high enough to energize the SS relays.
I need a dispute settled involving wiring a 1746-OB16 output card. Without giving any information concerning our “views”. How would you wire the...
4,171
Hello, I have a few boards, the same, which are: 1746-OB16/D It seems hard to find the manual online. Any help with that please. My question...
1,277
Here's what I've got... SLC504, 1746-OB16 (Transitor) DC sourcing output module. I'm planning on powering small solenoids with this (I...
3,293
Hello all, I am currently trouble shooting a SLC 505 control system. The output modules that are used are the 1746-OB16 and I am trying to find...
2,312
Can anyone please provide or point me in the direction as to where I can get the wiring diagram/ connection details for an Allen Bradley 16 point...
3,773
