Anyone have experience on this issue, please give me a guidance. Thanks
My setup:
I've 2 local SLC 5/05 (slot 0) chassis with 1747-BSN at slot 1. The setup for both local chassis is the same.
I've a remote chassis with:
slot 0 = 1747-ASB
slot 1 = 1746-NI16V
slot 2 = 1746-OB32
slot 3 = 1746-IB32
slot 4 = 1746-IB16
1) I'm not sure what is the programming I/O assignment for the analog and the digital modules. The analog require a Block Transfer? Does 1746-Ni18V module need to configure every bit for proper operation like 1794-IE8 or 1771-IFE?
2) The 1746-OB32 will use O:1.0 & o:1.1? 1746-IB32 will use I:1.0 & I:1.1? 1746-IB16 will use I:1.2? Correct me if I'm wrong.
3) Came across a Knowledgebase indicate that we can use 2 or more IB32 side by side when using 1 slot addressing.
Thanks.
Regards,
CK Chew
My setup:
slot 0 = 1747-ASB
slot 1 = 1746-NI16V
slot 2 = 1746-OB32
slot 3 = 1746-IB32
slot 4 = 1746-IB16
Thanks.
Regards,
CK Chew
