slc 5/04 & 1747-bsn redundant network
idowulawrence
Apr 2010
eket
Hi guys, in a redundant dh+ network consisting of one IO scanner (1747-ASB) having a combination of different IO modules in a 13 slot chassis connected to a pair of redundant dual 4 slot chassis each with one slc 5/04 and a backup scanner (1747-BSN), this redundant array is to connect on RIO, however this same network is to connect to other 4 slc 5/04 (on dh+) a wonderware HMI (on dh+) and a DF1 device. I hope that is possible
Read and understand the 1747-BSN User Manual:
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1747-um010_-en-p.pdf
The architecture you describe is typical of SLC-5/04 and 1747-BSN redundancy systems. The 1747-BSN provides automatic switching of the RIO channel between the two 1747-BSN modules, and also provides a way to switch the DH+ and RS232 ports between the two controllers.
ControlLogix Redundancy is Rockwell Automation's standard offering for redundant control systems. The SLC-500 redundancy system does not offer many of the standard features of ControlLogix redundancy, including switching of ControlNet and EtherNet/IP networks as well as automatic crossloading of data tables and edits between controllers.
I would like to seek assistance on configuring the G File on Backup Scanner 1747-BSN for the following setup Rack 0 (Where the Main [2 x CPU SLC...
1,874
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,611
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,050
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,526
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,252
