slc 501 to 1747-UIC
jimcav
Dec 2004
new jersey
229
Hello
I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it would be:
4 to 4
5 to 5
8 to 8
This would be if I made the cable with RJ45 jacks on both ends.
jim cav
I just use a standard Cat5E cable there. Just be sure not to accidentally plug it directly into your laptop!
Greetings All, Just wanted to share a little adventure I has last evening. A facility that we are leasing calls and has a problem with a piece of...
1,808
I'm going nuts trying to figure this one out. I have a processor that faults every time the power is cycled. The thing is, when it faults it...
18
7,253
I'm having problem connecting to the 501 plc with 1747-uic adaptor windows xp sp3 recognises the adaptor but rslinx cannot locate the plc. I tried...
20
5,130
I am not sure is transmit enable is the proper term, but that is what we call it. Pin 5 (or 3 depending on how you look at it) of a SLC503's...
2,712
Two of my power module for SLC 501 have failed myteriously. Both of them were functional a year ago when those systems were build. While starting...
4,345
