1746-P4 Power module for SLC 501 failure
Amitava
Feb 2006
Houston, Tx
Two of my power module for SLC 501 have failed myteriously. Both of them were functional a year ago when those systems were build. While starting up the system now, after a year they were idle, I found the following:
1st 1746-P4 module
a. CPU shows fault
b. The fault goes away when the power module was replaced
c. The 24V user power shows 23.7V with nothing connected to the module (no load)
2nd 1746-P4 module
a. The PLC system starts up momenteraly, and shuts down in couple of sec.
b. When the power module was replaced, the system works perfect
c. The red LED doesnt light up on the module
d. The 24V user power gives 23.7V (without any load) even withought the red light being lit.
Please post a reply if you ever faced such a problem, or have any sugestion.
Also can anyone give me the back-plain pin-outs of 1746-P4
I need a dispute settled involving wiring a 1746-OB16 output card. Without giving any information concerning our “views”. How would you wire the...
4,171
Hi All, I'm having trouble powering up the PS on the SLC500. I have smoked 2 fuses (250V 3A) and the jumper is definitely in the right position...
2,246
hello again. I have been having problems with my control shutting down because of an RTD module fault. When I remove the load from the module it...
2,790
When i power up the power supply nothing happenes. I am wondering if there is a fuse in the power supply somewhere??? I've tried it on differnt...
3,432
HI EXPERTS I HEAR HUMMING NOISE FROM POWER SUPPLY 1746-P1 ANY ADVICE. THANKS EXPERTS
4,000
