ceilingwalker
hello again. I have been having problems with my control shutting down because of an RTD module fault. When I remove the load from the module it works fine. I have added four additional RTD probe's and I think it has put the power supply over the edge. The power supply I have is a 1746-P4 and it is installed in a 13-slot rack that is fully populated. When I go to I/O configuration and select "power supply" it brings up a message that says something to the effect that the power supply is overloaded. When I remove the four additional RTD's the problem goes away. That being said, how do I select the next larger power supply? Is it safe to assume that the next number higher (P5) supply would suffice? Thank you for the help.
