Automatic Screen Select PVP7
TheRooster
Jan 2022
USA
39
Hello everyone,
I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB PanelView Plus 7 Standard. What I'm trying to do is switch screens when specific steps are reached in auto mode, but still allow the operator to manually select screens whenever they want. I thought I could do this by putting a ONS in to switch the screens just for one scan, but I saw a slow update rate in the HMI and decided to add a timer. For some reason it's only working about 25% of the time, any ideas?
Attached ss of logic and pertinent hmi settings.
Write the screen number to screen select. When current screen = screen select, ONS clear screen select back to zero. I don't have one handy to try, there's a chance those two tags / connections are swapped.
I wonder if it's worthwhile to put a >0 there also. I don't remember exactly how I've done it.
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
84
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,836
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,342
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,809
Hi, I get an error message "version on your device is not compatible with WinCC Flexible" I know i have to update the OS, and i found a document...
34
8,431
