Automatic OS update of operator panel
You can create an image to flashcard, and restore an image from flashcard.
But you cannot load a modified runtime this way.
For the xPx77 panels you have to have an online connection to load a runtime.
You can use the PC/PPI cable to load the runtime and/or update the OS on the panel.
It is right there in the screenshot you sent from the Set PG/PC Interface utility.
edit: And, you can even use the backtransfer function in WinCC Flexible to load the archived project file, if it exists.
Hello Guys,
I am getting this error when trying to backup using Prosave with the USB host-host cable.
I tried using the PC/PPI cable but the HMI is powered on the RS485 port with PLC. So if I disconnect and connect my laptop using PC/PPI cable the HMI doesn't turn on.
In the other thread was posted a link to the manual for USB host to host interface.
If you read that you would find that only a few adapters are supported, and the one you have is not one of them.
The TP177B has a separate 24V power supply plug. It should not turn off because you remove the RS485 cable.
Hello guys,
I finally did the backup of the project and then transfer my new project using WinCC Flex 2005 and also Prosave V7.3
(I didn't have to update the OS on HMI)
I used USB host to host cable by Plugable which is available on Amazon.
IDK why it wasn't working when I tried the same cable with Prosave V7.4
Anyways, Thank you so much for your help guys
Regards
Liston
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
84
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
583
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,834
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,341
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,807
