Automatic Grid-Generator Transfer Panel
Bubblegun
Apr 2024
Sakarya
Hello,
I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up to 100-125A. I will also install mechanical protection. Besides 2 contactors, 2 time relays, and 2 protection relays, what other materials do I need? Would it be more reasonable to choose a 4-pole or a 3-pole automatic transfer switch? How can I draw the schematic of this transfer panel? I would be very grateful if you could help. Thank you.
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
591
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,841
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,348
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,843
Hi, I get an error message "version on your device is not compatible with WinCC Flexible" I know i have to update the OS, and i found a document...
34
8,440
