Automatic OS update of operator panel
Hi sorry to move away from the topic but I have another doubt.
If you see in the picture I attached, the backup procedure says that i have to set PG/PC interface in SIMATIC MANAGER.
I am working with s7-200 PLC which uses MicroWin and not Simatic manager. So is it the same as setting PG/PC interface in MicroWin?
No. Simatic Manager uses the S7ONLINE access point. MicroWin uses the Micro/Win access point.
To illustrate this point, open Windows Control Panel, and the Set PG/PC Interface icon.
Then you will see a drop-down of access points, one is called S7ONLINE (which is set in SIMATIC Manager, and another is called Micro/Win, which is set in MicroWin.
So I need to install Simatic Manager? or can I do it in windows control panel?(see pic)
Yes, you are at the right place.
You need to set S7ONLINE to an interface with TCP/IP.
Do NOT set it to TCP/IP(AUTO) !
edit: My bad. TP177B Mono DP does not have an ethernet port.
Liston.Furtado said:
Also I'm assuming that the backtransfer was enabled during the initial transfer because I have some old revisions of the project and there are .pdz files. Hope I'm right.
I think that you can change the .pdz to. .zip and then unzip the file which should give you the .hmi and .ldb files.
Did you try this ?
No Jesper. Because what I have is the older revisions of the project files which will not have the current changes that are running on the HMI. so I want the latest project from the HMI.
The archived project file will be on a flashcard in the slot in the rear of the panel.
If there is no flash card then there is no project archive on the panel.
If the flashcard is there, and the archive file is on the card, then you can manually copy the file to your PC in a card reader.
Oh...that's interesting.
And can I do the reverse? if I have to download a new project on the HMI?
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
84
Hello everyone, I'm having trouble solving this one and was hoping someone could help. I have a AB CompactLogix L16ER PLC connected to a AB...
584
Hello everyone, I was hoping someone with a lot of experience with Automatic Device Configuration would chime in with any of your thoughts on this...
1,834
Hello. At my job I get from clients lists of their inputs and outputs (hundreds of them) and what they want the program to do. So I have to type...
1,342
For some reason the PLC (TM221CE16T) saves all Memory Bits and Memory Words automatically so after a cold restart it restores not only %MW0 to...
18
4,809
