AB 1746-P2 Power supply
nelg84
Apr 2014
Brisbane
Hi All,
I'm having trouble powering up the PS on the SLC500. I have smoked 2 fuses (250V 3A) and the jumper is definitely in the right position for 240V which is what I'm feeding it.
Has anyone else had this problem? Do I need an isolation Transformer or similar for this PS? The second fuse that blew took about 10 seconds which leads me to believe there could be an undervoltage from the supply.
Any help would be appreciated.
Cheers
Have you tried powering up the power supply without anything connected to it, this would help to isolate what id causing the fuse to blow, if it powers up Ok then it could be something in the rack drawing to much power for the power supply to handle but it more likely that the power supply id faulty.
Alan
Thanks Alan. I powered up the ps on its own and did the same thing. I looked at the board and there's no obvious signs of failure - caps are all flat on top and no blackness anywhere on board.
I think this has happened to others but couldn't get an answer from their discussion. I thought maybe there'd be a sacrificial part on the board besides the fuse that could be replaced - not sure looking at it.
Sounds like something on the input side of the switch mode power supply in the 1746-P2, if you have a good knowledge of switch mode power supplies you may be able to repair it yourself.
Alan
hello again. I have been having problems with my control shutting down because of an RTD module fault. When I remove the load from the module it...
2,790
When i power up the power supply nothing happenes. I am wondering if there is a fuse in the power supply somewhere??? I've tried it on differnt...
3,432
HI EXPERTS I HEAR HUMMING NOISE FROM POWER SUPPLY 1746-P1 ANY ADVICE. THANKS EXPERTS
4,000
I need a dispute settled involving wiring a 1746-OB16 output card. Without giving any information concerning our “views”. How would you wire the...
4,171
Two of my power module for SLC 501 have failed myteriously. Both of them were functional a year ago when those systems were build. While starting...
4,347
