rrparker07
I'm going nuts trying to figure this one out.
I have a processor that faults every time the power is cycled. The thing is, when it faults it won't let me online to see what the fault is. I get a message that states "can't go online with faulted processor "no program"". It also says must perform download. Under that, there are two buttons: one that says cancel and won that says load from EEPROM. If I click load from EEPROM it loads fine. If I download the program it works. I have tried different combinations of the memory module bits S1/10 - 12 to see if this would help. When I changed them, I also burned the EEPROM so they would match. The battery is brand new.
One side note, when I burn the EEPROM it kicks me offline. I'm fairly new to PLC's and don't know if you're supposed to get a message saying it burned OK.
Any help would be greatly appreciated.
Thanks,
Roy
Thanks,
Roy
